<- Main site
Home
Help
Search
Calendar
Members List
Login
Register
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
The 2CV Racing Club
2CV Racing Club Forum
24h-Race
Refuelling and tuff jugs
Pages:
1
2
« previous
next »
Author
Topic: Refuelling and tuff jugs (Read 1924 times)
Veteran
Re: Refuelling and tuff jugs
Reply #15 on:
June 22, 2011, 13:17:06 »
thanks Paul
Logged
Simon Crook - See Racing (well going around) in 09
Veteran
Reply #16 on:
June 22, 2011, 19:17:42 »
Ah, ok; I thought you were talking modifying the spout bit, rather than the filler neck (which is what you said...) - I was having a quick interweb session after getting home from a gig in Glasgow, a bit frazzled perhaps!
(must stop accepting gigs on school nights...)
D.
Logged
Racer
Reply #17 on:
June 26, 2011, 15:06:00 »
to clarify
i assume it doesn't matter where the exhaust exits so long as we reach the required noise levels.
Logged
Veteran
Reply #18 on:
June 26, 2011, 19:23:50 »
for croft the exhaust must point away from the noise meter.
On a rhd car this means it needs to exit towards the drivers side.
Logged
Racer
Reply #19 on:
June 28, 2011, 18:07:36 »
is the noise measured from lhs then? or rhs
Logged
Veteran
Reply #20 on:
June 29, 2011, 00:13:07 »
Measured from the left, hence the right-facing exit.
Logged
Veteran
Reply #21 on:
June 29, 2011, 08:27:42 »
the fixed noise meter is at Sunny Out about 10m from the track edge on the lhs, the exhaust needs to point away from this.
Logged
Veteran
Reply #22 on:
August 16, 2011, 22:24:36 »
Rubber hose and cap arrived today; thanks very much.
Logged
Veteran
Reply #23 on:
August 17, 2011, 11:19:38 »
Mine has arrived too, and now fitted
Logged
barney rubble
Rookie
Reply #24 on:
August 19, 2011, 17:06:11 »
Phil has sugested that when you fit your fuel neck in order to make the fuel cap fit as it is a bit tight(unlike the one in the prototype) you should grind out the weld on the small vent pipe i think you would be better suited taking a small amount off the bottom metal part of the filler cap this to me makes much more sence! grinding the weld out should be ok but if it has caused you a problem come see me at snet in the gadget garage and i will sort it out for you or call me 07977579446
Cheers Tony AKA "the gobby mechanic"
Logged
Veteran
Reply #25 on:
August 19, 2011, 19:24:38 »
I just filed it a bit and it's fine; somewhat more subtle than grinding!
Logged
Racer
Reply #26 on:
August 20, 2011, 12:10:55 »
Is this going to be the year of carborundum and saniless grit in the fuel filter then
Logged
Pages:
1
2
« previous
next »
Jump to:
Please select a destination:
Official Notices
=> Announcements
=> General Discussion
=> 24h-Race
=> Races (not 24 hr)
=> Economy Class
=> Events (Non-Racing)
=> For sale / wanted
=> Off topic
Loading...
